[Qgis-user] postgres connection
Alex Mandel
tech_dev at wildintellect.com
Thu Feb 5 15:57:17 PST 2009
Bernardo Rossi Doria wrote:
> hi
> Using qgis 1.0 on mac book pro OSX
> I already tested connection to localhost on port 5432 with earlier
> version of qgis
> Now when I test the same connection I get this answer:
> I tried to create new connections unsuccessfuly.
> Do I need to eliminate old connections? Howto ?
> thankyou
> bernardo
There's no reason you should need to delete old connections. Can you
verify that postgres is running and connect with another application
like psql or pgadmin?
Let us know if those work, so we can be sure it's something in QGIS.
Thanks,
Alex
