AW: [Qgis-user] Grid in print layout
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Mon Jul 27 13:29:37 PDT 2009
Hi all
Grid lines for the print composer are planned for the next version (presumably 1.3).
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Ricardo Filipe Soares Garcia da
Gesendet: Mo 27.07.2009 22:24
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Grid in print layout
Hi
I'm also begging for such a tool. Like you, I've been manually
creating these grids for printing purposes only. It gets painful when
I want to display the coordinates in the bottom and right of the grid,
having to create several layers... In fact I've been looking for a
quick way to add them in various open source gis tools and came up
short. So far GRASS is the only that I've seen that allows one to
create a such a grid in an easy way (I've tried Qgis, gvSIG, uDIG,
OpenJUMP, Kosmo and GRASS). On the downside, with GRASS I have to
create a new region and mapset and import my files, which is also time
consuming.
I am considering learning gmt, mainly to be able to draw these grids
on top of my maps... (though I am sure it will be useful for other
things as well)
So, to conclude, it would be really cool if Qgis had such a feature!
On Mon, Jul 27, 2009 at 5:57 PM, Martin Bolte<mail at silico.net> wrote:
> Hello,
> I have to make lots of maps as PDF-files and need to put a grid overlay
> on each map. Creating all these with the plugin "graticule creator" or
> making them via ftools - research tools - vector grid is a tedious task
> as I need to do a lot of steps in order to have the correct coordinates
> of the grid lines displayed in the map layout.
> Has anybody a clue on how to speed this up?
> There should be some development on a tool allowing to insert such a
> grid directly within the print composer dialogue.
> Kind regards
> Martin
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
