[Qgis-user] Error in download webpage?
Agustin Lobo
alobolistas at gmail.com
Mon May 18 10:35:05 PDT 2009
The page is much easier to follow now, thanks a lot.
I wonder if the last stable release (i.e. 1-0-2 now) could
have a different color background. Also, in the
page for plugins, I would add a note stating that
the advised method to install plugins is through
the Plugin Installer within QGIS itself.
Agus
Otto Dassau wrote:
> Hi,
> On Fri, 15 May 2009 11:44:40 +0200
> Agustin Lobo <alobolistas at gmail.com> wrote:
>> The critical point is better for whom? I understand that it's easier
>> for administration, which is important as time is scarce. But we
>> should also consider whether it's better for the users: many of them
>> do not even know what's stable or unstable in this context.
>> So we should find a balance. For users, in general, simple pages having
>> the fundamental
>> material and only the fundamental material are the best.
>> Probably a page as suggested by Otto is a good balance.
>> In particular putting stable before unstable and source is essential.
> We updated the download area according to your suggestion, set a fix width for
> the table and will revise it this evening. If you have more ideas to improve the
> page for users, just tell us.
> regards,
> Otto
>> Thanks for taking care of the site.
>> Agus
>> Tim Sutton wrote:
>>> Hi
>>> Werner Macho wrote:
>>>> Hi!
>>>> corrected it - if you find more typos - please report ..
>>>> Speaking from Unstable and Stable .. well probably we should seperate
>>>> it - but
>>>> Source Code IS already on an own page ..
>>>> I guess it's inside the table to have all things we provide for
>>>> download in just one page..
>>> Managing everything in one table is better I think - simplification
>>> over complication is good :-) In the table you can just type unstable
>>> into the search box to see just unstable packages. You can also sort
>>> by columns etc. That should give enough flexibility for those who want
>>> it.
>>> Thanks for fixing the typo!
>>> Regards
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090518/d80f4d05/attachment.vcf>
