[Qgis-user] Metaedit error
Alex Mandel
tech_dev at wildintellect.com
Mon May 25 11:43:59 PDT 2009
I think most of the files included are template files for various
metadata standards, not sample data. These come into play when you are
making metadata for a file that has none. But they will all be blank in
terms of values.
If you want a test file, here's one we used during development
http://apps.sourceforge.net/trac/qgismetaedit/browser/trunk/test
Note, the plugin does not allow saving yet. I'm in the process of
changing the xml backend to allow for international characters and saving.
Alex
Agustin Lobo wrote:
> Alex,
> I'm trying the plugin with your sample data, but I'm
> very confused. I just get empty fields. Don't you
> have files with actual metadata so I can actually
> display/edit with qgismetaedit?
> Agus
> Alex Mandel wrote:
>> We know that non ascii characters will fail to open, including many of
>> the template files (borrowed from CatMDEdit). The next big fix in the
>> pipes should include support for utf-8 and saving of edits, but no
>> promises on how long it's going to take we have to change the xml parser
>> for a new one.
>> Please try it with your own data, feedback, bugs, and contributions are
>> welcome. In fact with this release we formally invite translators to
>> contribute their skills, we've started German and Spanish. Contact me if
>> you want to translate and I'll get you started.
>> http://apps.sourceforge.net/trac/qgismetaedit/wiki/Translations
>> Thanks,
>> Alex
>> Agustin Lobo wrote:
>>> After installing the upgraded plugin, the panel opens fine, thanks. I'll
>>> test it this evening with the data you provide and will let you know.
>>> Agus
>>> Alex Mandel wrote:
>>>> Martin Dobias wrote:
>>>>> On Mon, May 4, 2009 at 5:22 PM, Agustin Lobo <alobolistas at gmail.com>
>>>>> wrote:
>>>>>> According to Synaptic (I'm runing ubuntu 8.04) I have:
>>>>>> python-qt3 (should I get rid of it?)
>>>>>> python-qt4 4.3.3-2
>>>>>> libqt4-* 4.4.0
>>>>>> is this a problem of python-qt4 4.3.3-2 ? There is nothing newer
>>>>>> for ubuntu
>>>>>> 8.04, as far as I've been
>>>>>> able to find out.
>>>>> Yes, I think pyqt 4.3.3 can't be used as a wrapper for new classes in
>>>>> qt 4.4.
>>>>> Martin
>>>> I have actually removed this dependency from the svn version, so it
>>>> works on pyqt 4.3 now. I'll try to get it up in the contrib repo today.
>>>> We also started adding translations and will be looking for people to
>>>> test and help edit them.
>>>> Thanks,
>>>> Alex
