[Qgis-user] qgCSW plugin needs the "filter" python module to be installed
Giovanni Manghi giovanni.manghi at gmail.com
Sun Nov 8 04:49:42 PST 2009
same question here!
cheers
-- Giovanni --
On Sun, 2009-11-08 at 11:02 +0100, Νίκος Αλεξανδρής wrote:
> Hi list!
> While I have successfully installed all possible plugins available
> through the Plugin Installer (and the various Repositories) I am stuck
> in one: the qgCSW. It complains as follows:
>   "The plugin depends on some components missing on your system. You
> need to install the following Python module in order to enable it:
> filter"
> I can't find which package includes this "filter" module. Is it a
> default one? Is it my bad configuration that does not allow its loading?
> Thanks, Nikos
> Qgis-user mailing list
