[Qgis-user] Re: QGIS intallation, Windows XP, TIFFUnsetField, libtiff.dll
Patrick Giraudoux
patrick.giraudoux at univ-fcomte.fr
Sun Nov 29 23:15:27 PST 2009
> Hi Patrick,
> On Sun, 29. Nov 2009 at 12:06:45 +0100, Patrick Giraudoux wrote:
> > I have seen on the list that Agustin Lobo had a quite similar trouble:
> > <http://n2.nabble.com/Problem-with-TIFFSetField-in-*libtiff*-*dll*-td2271128.html
> <http://n2.nabble.com/Problem-with-TIFFSetField-in-libtiff-dll-td2271128.html>>,
> > but I cannot find out if whether it was solved or not and if so how...
> In that thread Frank suspected that there is a *libtiff*.*dll* in Agus
> system32
> directory. That was the case and Agus removed it. That helped.
Yes, but I found that libtiff.dll was NOT in C:/WINDOWS/system32, but is
well present in C:\OSGeo4W\bin
> Unfortunately it's not possible to have *Windows* find OSGeo4W's
> *libtiff*.*dll*
> before the one in system32 and removing it or replacing it with the
> OSGeo4W
> version might break the software that originally put it there.
> But in that case it might help to put the original *libtiff*.*dll*
> into the same
> directory as the .EXE of the other software.
This is not clear to me. libtiff.dll is currently in C:\OSGeo4W\bin
where I can find qgis.bat but not qgis.exe. Do you mean that I should
move libtiff.dll into C:/WINDOWS/system32 ?
Thanks for the hint,
Patrick
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091130/c9d64083/attachment.html>
