[Qgis-user] Version 1.3, Spatialite issues on Mac OS X and Linux
Carlo A. Bertelli (Charta s.r.l.)
bertelli at charta.acme.com
Thu Oct 29 15:43:22 PDT 2009
Yes, I can confirm that changing the language to US Englis (just
changing the language in the preferences) solves this issue. It worked
in version 1.1 (I remember that building QGis 1.1 on Linux, I faced
lots of warnings and errors on the language strings).
c
On Thu, Oct 29, 2009 at 11:35 PM, Carlo A. Bertelli (Charta s.r.l.)
<bertelli at charta.acme.com> wrote:
> Hello,
> I thought it was only a problem on Os X, but now I think it's an issue
> with some italian string and Mimas 1.3.
> In the afternoon I upgraded my ArchLinux machine with Mimas 1.3 and I
> tried it with the sample data from:
> http://www.gaia-gis.it/spatialite/test-2.3.sqlite.gz
> Unexpectedly I got the same result. This is the italian error message:
> Errore durante la connessione verso:
> sembra essere un DB SQLite valido, ma non uno SpatialLite ...
> A possible translation sounds (sorry, I'm to lazy to verify it)
> Error during the connection to:
> seems to be a valid SQLite DB, but not a SpatiaLite ...
> The name of the file (test_2.3.sqlite) does not come out. I wonder why.
> Well, it could be my fault (all my machines refuse Spatialite, it' a
> plot against me!), but I think there may be other reasons.
> Carlo
> On Thu, Oct 29, 2009 at 2:57 PM, William Kyngesburye
> <kyngchaos at kyngchaos.com> wrote:
> I haven't really paid attention to the spatialite thread. Reading
> spatialite works for me on Leopard and Snow, using the spatialite test
> database. Both full and standalone Qgis.
> Can you reproduce the problem with the test database?
> The /usr/local spatialite shouldn't cause problems for Qgis (my
> builds), it's linked to the framework (OSX is very particular about
> link paths, unlike linux).
> Qgis (on OSX) also doesn't use the PATH. OSX apps in general don't
> use the PATH, or any env variables.
> Note: I did create a "GDAL Complete" package a few weeks ago.
> On Oct 29, 2009, at 3:59 AM, Carlo A. Bertelli (Charta s.r.l.) wrote:
> Ciao,
> as you could have seen on the list, my problem with spatialite files
> is not solved. QGis 1.3 (QGis+frameworks and updated GDAL framework).
> I know we should wait for GDAL 1.7 to write to spatialite, but I have
> QGis 1.1 on Linux and it reads the same files that QGis refuses on
> Leopard.
> I think it's a problem with my installation, I have Spatialite
> (command line tools, Gui and Gis) installed in /usr/local, maybe this
> could cause a conflict, maybe it's only a $PATH issue, but I've tried
> everything and it doesn't work. I have a map with a hundred layers and
> the shapefile version (even if spatially indexed) is so slow in
> comparison to spatialite that I really miss this feature.
> TIA for any help provided.
> BTW, may I put my 1+ on the all-frameworks idea again (even on Leopard)?
> c
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
Carlo A. Bertelli
Charta servizi e sistemi per il territorio e la storia ambientale srl
Dipendenze del palazzo Doria,
vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
tel. +39(0)10 2475439 fax +39(0)10 2475439 gsm:+39 393 1590711
e-mail: bertelli at charta.acme.com http://www.charta.acme.com
