[Qgis-user] (no subject)
Lionel Roubeyrie
lionel.roubeyrie at gmail.com
Mon Jul 26 04:43:05 PDT 2010
Hi all,
it's not an abnormal plugin fonctionnality but a standard error
message saying there's some python unsatisfied dependencies, like you
can read at the end of the error message or from the shell :
"ImportError: No module named matplotlib.pyplot". Just have to install
matplotlib and all will be ok. After that, when I was young I learned
a basic rule of life saying if I want an information, I have to
correctly ask the question and not so optionnaly be civilized with an
simple "hello". Didn't see that in the first post...
2010/7/26 Giuseppe Sucameli <brush.tyler at gmail.com>:
> Hi Noli,
> the Python Plugin Installer shows the unsatisfied dependencies yet.
> After the error message you should see the "Error loading plugin"
> dialog which says to you there are unfulfilled dependencies.
> Instead it's strange to see the error message!
> Trying to install other plugin with unsatisfied dependencies I don't
> see it, but the "error loading plugin" dialog only.
> So it's an abnormal plugin behaviour.
> Cheers.
> Hi Noli,
> Cheers.
> On Mon, Jul 26, 2010 at 3:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> I think this problem is very typical problem for plugins with
>> dependencies with other python packages.
>> It would have been better if plugins would show the dependecies
>> message so user could download and install the package.
>> In this case, just tell the user to download and install the matplotlib
>> package.
>> http://matplotlib.sourceforge.net/users/installing.html
>> Noli
>> On 7/26/10, Carson Farmer <carson.farmer at gmail.com> wrote:
>> > Except that will remove all plugins! What you probably really want is:
>> > rm -rf /Users/hermanpalaquium/.qgis/python/plugins/contour
>> > Which will only remove the contour plugin, which is failing to load
>> > because matplotlib isn't installed...
>> > I think you can also do this from the Python plugin installer by
>> > selecting to remove the plugin?
>> > Carson
>> >> Traceback (most recent call last):
>> >> File
>> >> "/Applications/Qgis.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> >> line 119, in loadPlugin
>> >> __import__(packageName)
>> >> File
>> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/__init__.py",
>> >> line 28, in
>> >> from contour import Contour
>> >> File
>> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/contour.py",
>> >> line 38, in
>> >> import matplotlib.pyplot as plt
>> > Carson J. Q. Farmer
>> > ISSP Doctoral Fellow
>> > National Centre for Geocomputation
>> > National University of Ireland, Maynooth,
>> > http://www.carsonfarmer.com/
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
Lionel Roubeyrie
http://youarealegend.blogspot.com
