[Qgis-user] (no subject)
Giuseppe Sucameli
brush.tyler at gmail.com
Mon Jul 26 06:40:12 PDT 2010
Hi Lionel,
On Mon, Jul 26, 2010 at 1:43 PM, Lionel Roubeyrie <
lionel.roubeyrie at gmail.com> wrote:
> Hi all,
> it's not an abnormal plugin fonctionnality but a standard error
> message saying there's some python unsatisfied dependencies, like you
> can read at the end of the error message or from the shell :
> "ImportError: No module named matplotlib.pyplot". Just have to install
> matplotlib and all will be ok.
AFAIK normally that exception is intecepted by the Python Plugin Installer
that shows the unsatisfied dependencies.
Did you try what happens with other plugins?
AFAICS no error message is shown by the other plugins with
unfulfilled dependencies.
After that, when I was young I learned
> a basic rule of life saying if I want an information, I have to
> correctly ask the question and not so optionnaly be civilized with an
> simple "hello". Didn't see that in the first post...
I agree, but it's better to avoid unnecessary polemics.
Shortly before starting this thread, Herman write another thread
titled "what happens?.." that starts:
"hi tim and qgis users".
So I think that it's only a blunder, nobody would start a thread
without subject and greeting.
Cheers.
2010/7/26 Giuseppe Sucameli <brush.tyler at gmail.com>:
> > Hi Noli,
> > the Python Plugin Installer shows the unsatisfied dependencies yet.
> > After the error message you should see the "Error loading plugin"
> > dialog which says to you there are unfulfilled dependencies.
> > Instead it's strange to see the error message!
> > Trying to install other plugin with unsatisfied dependencies I don't
> > see it, but the "error loading plugin" dialog only.
> > So it's an abnormal plugin behaviour.
> > Cheers.
> > Hi Noli,
> > Cheers.
> > On Mon, Jul 26, 2010 at 3:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
> >> I think this problem is very typical problem for plugins with
> >> dependencies with other python packages.
> >> It would have been better if plugins would show the dependecies
> >> message so user could download and install the package.
> >> In this case, just tell the user to download and install the matplotlib
> >> package.
> >> http://matplotlib.sourceforge.net/users/installing.html
> >> Noli
> >> On 7/26/10, Carson Farmer <carson.farmer at gmail.com> wrote:
> >> > Except that will remove all plugins! What you probably really want is:
> >> > rm -rf /Users/hermanpalaquium/.qgis/python/plugins/contour
> >> > Which will only remove the contour plugin, which is failing to load
> >> > because matplotlib isn't installed...
> >> > I think you can also do this from the Python plugin installer by
> >> > selecting to remove the plugin?
> >> > Carson
> >> >> Traceback (most recent call last):
> >> >> File
> "/Applications/Qgis.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> >> >> line 119, in loadPlugin
> >> >> __import__(packageName)
> >> >> File
> >> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/__init__.py",
> >> >> line 28, in
> >> >> from contour import Contour
> >> >> File
> >> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/contour.py",
> >> >> line 38, in
> >> >> import matplotlib.pyplot as plt
> >> > Carson J. Q. Farmer
> >> > ISSP Doctoral Fellow
> >> > National Centre for Geocomputation
> >> > National University of Ireland, Maynooth,
> >> > http://www.carsonfarmer.com/
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Giuseppe Sucameli
> Lionel Roubeyrie
> http://youarealegend.blogspot.com
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100726/17f337e2/attachment.html>
