[Qgis-user] CSWclient is available
Alexander Bruy
alexander.bruy at gmail.com
Thu Oct 21 00:45:05 PDT 2010
No problems, Paolo. This is my work as plugin developer.
On the contrary I am thankful for testing.
But I can't reproduce this bug. I add
http://ows.provinciatreviso.it/geonetwork/srv/it/csw?request=GetCapabilities&service=CSW
to the server list. Then switch to the Search tab and start search:
keyword - geo
bbox - set global
When I select any record in results I'm able to press
Metadata and View XML buttons and there are no errors.
May be you have outdated plugin? Current version is 0.0.8
2010/10/21 Paolo Cavallini <cavallini at faunalia.it>:
> Alex, you'll hate me: I'm still tormenting you.
> I get errors
> from
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/paolo/.qgis/python/plugins/cswclient/cswclientdialog.py", line 692, in
> showMetadata
> dlg.textXml.document().setDefaultStyleSheet( myStyle )
> AttributeError: 'CSWResponseDialog' object has no attribute 'textXML'
> I understand it's a problem from the server, but I guess this should be handled more
> cleanly by the plugin.
Alexander Bruy
