[Qgis-user] attribute query by substring or regexp
Volker Fröhlich
volker27 at gmx.at
Thu Jan 27 12:14:16 PST 2011
For shapefiles, the tilde operator doesn't seem to work for queries, but it
works in the attribute table's search. That could be a starting point for an
export, if that is acceptable.
FIELD_NAME ~ '^2'
The Regular Expression above selects geometry which's field_name starts with a
2.
Otherwise you could use LIKE and ILIKE, but they are not as powerful. They
should also work for querying shapefiles.
And as Noli said, conversion is also a possibility.
You might want to see
http://www.postgresql.org/docs/8.1/static/functions-matching.html
Volker
Am Donnerstag 27 Januar 2011, 02:01:23 schrieb maning sambale:
> Hi,
> Any tips on conducting substring query to limit display of polygons?
> For example, I was given a point shapfile containing a long
> description text n the attribute table and I want to select/display
> only the polygons containing a series of substring/text/values.
