[Qgis-user] attribute query by substring or regexp
maning sambale
emmanuel.sambale at gmail.com
Fri Jan 28 01:05:04 PST 2011
Noli and Volker,
Thanks for the tip. I'll try both approach.
2011/1/28 Volker Fröhlich <volker27 at gmx.at>:
> For shapefiles, the tilde operator doesn't seem to work for queries, but it
> works in the attribute table's search. That could be a starting point for an
> export, if that is acceptable.
> FIELD_NAME ~ '^2'
> The Regular Expression above selects geometry which's field_name starts with a
> 2.
> Otherwise you could use LIKE and ILIKE, but they are not as powerful. They
> should also work for querying shapefiles.
> And as Noli said, conversion is also a possibility.
> You might want to see
> http://www.postgresql.org/docs/8.1/static/functions-matching.html
> Volker
> Am Donnerstag 27 Januar 2011, 02:01:23 schrieb maning sambale:
>> Hi,
>> Any tips on conducting substring query to limit display of polygons?
>> For example, I was given a point shapfile containing a long
>> description text n the attribute table and I want to select/display
>> only the polygons containing a series of substring/text/values.
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
