[Qgis-user] change CRS of layer
Brad Nesom
gisbradokla at live.com
Sun Jul 31 19:48:58 PDT 2011
as long as the incorrect layer is shp. you can delete (rename would be
better) the prj file.
On Sun, Jul 31, 2011 at 4:40 AM, Matt Boyd <mattslists at gmail.com> wrote:
> If the layer isn't being picked up correctly in the first place I'd go:
> create new project: set project CRS to the one the layer is in
> load the vector file.
> Save As ...
> I'm nto sure how QGIS would transform a vector file that had the
> incorrect CRS but the default (according to the 1.7 docs I read) is to
> load the unkown vector file as the project CRS.
> I'm vaguely recalling a few extra steps in getting the right CRS in
> the older versions. I've been on 1.7 & 1.8 for long enough to forget.
> Matt
> On Sun, Jul 31, 2011 at 7:24 PM, Frank Sokolic
> <sokolic at worldonline.co.za> wrote:
> > Hi Walter,
> > In QGIS 1.6 you can set the layer CRS in the layer properties. Open the
> > layer properties and go to the General tab - you will see a button
> labelled
> > 'Specify CRS'.
> > If your layer already has a CRS specified and you want to save it to
> another
> > CRS: right-click on the layer name and select the 'Save as' option. You
> can
> > then specify the CRS for the new layer.
> > Frank.
> > ________________________________
> > From: wludwick at mac.com
> > Sent:2011-07-31 11:06:00
> > To: qgis-user at lists.osgeo.org
> > Cc:
> > Subject: [Qgis-user] change CRS of layer
> > Tho i gather that one should be able to declare which CRS to use on a
> > particular layer, i seem to be missing the control(s -no mention of CRS
> in
> > the Layer menu, nor in the contextual menu that pops up when i
> right-click
> > on a layer) that should provide such functionality.
> > Is anybody experiencing the same? I am running version 1.6.0, which
> asserts
> > itself to be the current version (when i "Check QGIS version" from the
> Help
> > menu).
> > /w
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110731/1d320210/attachment.html>
