[Qgis-user] Editing polygons
Andreas Neumann
a.neumann at carto.net
Mon Jun 27 07:50:26 PDT 2011
Hi Laura,
This is probably easy to solve:
* Settings --> Snapping Options --> Checkbox "Enable topological
editing"
Does it work for you?
Depending on the QGIS version the setting may be at a different place
in the menu.
Andreas
On Mon, 27 Jun 2011 16:32:53 +0200, Laura Guillot wrote:
> I'm trying to reshape polygons of a lancover map, in order to make
> them to be more
> coincident with an overlaid raster image (orthophoto 1:5M).
> If I just move the nodes to the correct position, I create a correct
> line but leave a hole behind: the other
> polygon keeps its line where it was. See a pict here:
> https://sites.google.com/site/lguillotdummy/home/boundaryproblem.jpeg
> [1]
> Is there any way I could just move the lines as boundaries?
> I've tried by converting poygons to lines first, but the problem is
> very much the same: it seems like
> there is always a double line, one for each adjacent polygon.
> A possible solution would be having the lines automatically cut into
> segments, each going from one vertex to another.
> And having just one segment for each boundary. Is that possible? Is
> there a process to cut into segments after running polygons to lines?
> Or perhaps there is a cmpletely different way to accomplish the same
> goal: modifying the boundaries between polygons.
> Thanks!
> L
> Links:
> [1]
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
