[Qgis-user] Re: QGIS disappears: Right Desktop?
ahmad jauhari
mriduan62 at gmail.com
Thu Jun 30 20:21:04 PDT 2011
dear all,
I have managed to solve my problem. The problem is the file spqr
plugin. After this I delete the plugin file, QGIS works well. thanks
first, I rename the folder 'plugins', then create a new folder
'plugins' I copy some files plugins to the new folder and run QGIS, if
not problematic copy the plugins file again until the entire file
plugins is not problematic. finally your QGIS working again.
best,
zehari
On 6/30/11, Bernd Vogelgesang <bernd.vogelgesang at gmx.de> wrote:
>> I have a problem with QGIS 'master' (OS ubuntu 11.10), ie, after the
>> run and appears Splash Screen 'QGIS Master' then there is no more (not
>> working). Please help. thanks
> Maybe it's the same i experienced already in previous versions under
> ubuntu: qgis starts with the splash screen and after that, there is no
> program visible.
> In my case i found out, that qgis starts in the next desktop to the right
> from the desktop you started it.
> I do not know exactly how to solve this (editing the starting parameters
> manually i assume), but in the classic version, right-click qgis in the
> program window bar and select to move it to the next left desktop to have
> it again back to "normal".
