[Qgis-user] 1-band raster plugin and grass r.colors
maning sambale emmanuel.sambale at gmail.com
Thu May 19 05:14:18 PDT 2011
Thanks for the info.  So far, the grass rules I often used are
included. I'll dig deeper into how to create palettes and hope this
will be included in later versions.
>> Hi Maning,
>> Short answer: No.
>> I've only included a few default rules from Grass.
>> Note that "1-band raster colour" plugin is based on colour palette files
>> (one file per palette), and, AFAIK, Grass colour palette is rule based (this
>> means the colour palette is created on the go, when the user needs it).
>> Also note that you can add your own palettes, see [1] for explanations on
>> how to do it.
>> If you do so, could you please email me the palette so that I can add it
>> to the plugin distro.
>> HTH,
>> Benoit
>> On Wed, 18 May 2011 16:55:20 +0800, maning sambale
>> <emmanuel.sambale at gmail.com> wrote:
>>> Just a quick Q, does the 1-band raster colour table plugin[1] include
>>> all of GRASS r.colors'[2] default rule styles?
>>> [1]http://www.bc-consult.com/free/bcccoltbl1.html
>>> [2]http://grass.osgeo.org/gdp/html_grass64/r.colors.html
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
