[Qgis-user] OS X Lion - Experiences?
Noli Sicad
nsicad at gmail.com
Wed Nov 9 19:48:05 PST 2011
Good to know that QGIS in Mac OS X is getting stable.
However, there are 2 things that it is not working in QGIS Mac OS X, right now.
1. Georeferencing plugin (C++ plugin).
2. Rectangle, Oval and Diamonds (Digitizing) python plugin.
These 2 plugins are working properly properly in Ubuntu 10.04.
(I have 3 triple laptop (Window 7, Mac OS X (10.6.4) and Ubuntu
10.04), so I can switch back and forth from Mac OS X and Ubuntu at the
moment. Windows 7 is dormant at moment).
I prefer to use Mac OS X with QGIS since I could run several version
of QGIS by just renaming QGIS and installed another version).
Thanks.
Noli
On 11/10/11, Mars Sjoden <marsofearth at gmail.com> wrote:
> I have been using QGIS 1.7.1 Williams Framework build for the last while
> and I have NOT had the many problems with crashing using symbology.
> Fix: 1. Never Double-Click Layer in (legend) T.O.C. to Open Layer
> Properties (for some reason this caused random crashes for some of us poor
> folks)
> I Did This:
> QGIS/Preferences - General - Application - - > Double Click Action in
> Legend ----> Open Attribute Table
> No accidentally/unknowingly crashing when changing a symbol by accidentally
> double clicking to get at the layer Properties window.
> So far in this short time span, QGIS appears to have the edge over ArcGIS
> 9.3 and 10 for stability.
> Some infrequent crashes that may have been attributed to very large Raster
> Images 2-3Gb.
> Loving QGIS!!!
> mars
> On Mon, Oct 31, 2011 at 9:59 AM, Mars Sjoden <marsofearth at gmail.com> wrote:
>> Bug #4439 appears to be related to the bug I reported on this
>> On Sun, Oct 30, 2011 at 7:28 PM, William Kyngesburye
>> <kyngchaos at kyngchaos.com> wrote:
>> > Well, as said first step, I didn't see anything abnormal. I'm looking
>> at loaded libraries for anything that shouldn't be there, and maybe
>> something obvious in the call stack trace.
>> > The crash seems to be unique, so go ahead and create a new bug report.
>> If it turns out to be more related to an existing bug it can always be
>> closed.
>> > On Oct 30, 2011, at 2:44 PM, Mars Sjoden wrote:
>> > > Here is the Crash Log as per requested.
>> > > If I were to add this to the BUG list is there a particular bug Number
>> I should add this too.
>> > > Seems like there are quite a few related Bug #'s to this type of
>> > > crash.
>> > > mars
>> > > <QGIS 1.7.1-2 crashlog.rtf>
>> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> > http://www.kyngchaos.com/
>> > "History is an illusion caused by the passage of time, and time is an
>> illusion caused by the passage of history."
>> > - Hitchhiker's Guide to the Galaxy
