[Qgis-user] Problem with qgis-web-client configuration
Otto Dassau dassau at gbd-consult.de
Sun Dec 9 08:02:20 PST 2012
Hi Andreas and Salvatore,
I use the server from qgis 1.8 available for ubuntu and changing var
useGetProjectSettings to false did the trick.
Thanks a lot, now it works :)
Regards
Otto
BTW. Would it be better/necessary to use the server from QGIS trunk?
Am Sun, 09 Dec 2012 16:55:44 +0100
schrieb Andreas Neumann <a.neumann at carto.net>:
> Hi Otto,
> As Salvatore said you must use one of the GlobalOptions.js template files.
> I would also start the developers tools in Google Chrome or Firefox and
> have a look at the network requests the browser is making. You can then
> test the requests manually and compare with the Apache server log.
> It may also be that it is making request to GetProjectSettings and you
> have an older version of the server - in which case you can set
> var useGetProjectSettings = false;
> in GlobalOptions.js
> Andreas
> Am 09.12.2012 14:59, schrieb Otto Dassau:
> > Hi,
> > I installed qgis server version 1.8 using ubuntu precise. The WMS and WFS
> > work, if I add them to QGIS. Now I would like to play with the
> > qgis-web-client. I can see the web-client but the test maps "Hello" and
> > "Country" are loading and loading ... but are not visible.
> > I guess I missed something simple to configure. But the log files don't
> > say anything, except for some missing css files in blueprint.
> > Thanks for any hint
> > Otto
