[Qgis-user] Problem with qgis-web-client configuration
Andreas Neumann
a.neumann at carto.net
Sun Dec 9 08:13:52 PST 2012
Hi Otto,
In the next upcoming weeks we will increasingly use the options in
GetProjectSettings - which wouldn't work with GetCapabilities alone.
Right now it doesn't make much difference, but it will in the future -
esp. for metadata display or initial visible layers.
Also, if you want to use the advanced feature of separating the layer
drawing order from the order in the legend tree it only works with
GetProjectSettings.
Andreas
Am 09.12.2012 17:02, schrieb Otto Dassau:
> Hi Andreas and Salvatore,
> I use the server from qgis 1.8 available for ubuntu and changing var
> useGetProjectSettings to false did the trick.
> Thanks a lot, now it works :)
> Regards
> Otto
> BTW. Would it be better/necessary to use the server from QGIS trunk?
> Am Sun, 09 Dec 2012 16:55:44 +0100
> schrieb Andreas Neumann <a.neumann at carto.net>:
>> Hi Otto,
>> As Salvatore said you must use one of the GlobalOptions.js template files.
>> I would also start the developers tools in Google Chrome or Firefox and
>> have a look at the network requests the browser is making. You can then
>> test the requests manually and compare with the Apache server log.
>> It may also be that it is making request to GetProjectSettings and you
>> have an older version of the server - in which case you can set
>> var useGetProjectSettings = false;
>> in GlobalOptions.js
>> Andreas
>> Am 09.12.2012 14:59, schrieb Otto Dassau:
>>> Hi,
>>> I installed qgis server version 1.8 using ubuntu precise. The WMS and WFS
>>> work, if I add them to QGIS. Now I would like to play with the
>>> qgis-web-client. I can see the web-client but the test maps "Hello" and
>>> "Country" are loading and loading ... but are not visible.
>>> I guess I missed something simple to configure. But the log files don't
>>> say anything, except for some missing css files in blueprint.
>>> Thanks for any hint
>>> Otto
> Qgis-user mailing list
