[Qgis-user] Problem with qgis-web-client configuration
Otto Dassau
dassau at gbd-consult.de
Sun Dec 9 08:29:33 PST 2012
Hi Andreas,
thanks, I added a small note to the repo, that useGetProjectSettings should
be set to false for QGIS server versions <= 1.8.
Regards
Otto
Am Sun, 09 Dec 2012 17:13:52 +0100
schrieb Andreas Neumann <a.neumann at carto.net>:
> Hi Otto,
> In the next upcoming weeks we will increasingly use the options in
> GetProjectSettings - which wouldn't work with GetCapabilities alone.
> Right now it doesn't make much difference, but it will in the future -
> esp. for metadata display or initial visible layers.
> Also, if you want to use the advanced feature of separating the layer
> drawing order from the order in the legend tree it only works with
> GetProjectSettings.
> Andreas
> Am 09.12.2012 17:02, schrieb Otto Dassau:
> > Hi Andreas and Salvatore,
> > I use the server from qgis 1.8 available for ubuntu and changing var
> > useGetProjectSettings to false did the trick.
> > Thanks a lot, now it works :)
> > Regards
> > Otto
> > BTW. Would it be better/necessary to use the server from QGIS trunk?
> > Am Sun, 09 Dec 2012 16:55:44 +0100
> >> Hi Otto,
> >> As Salvatore said you must use one of the GlobalOptions.js template
> >> files.
> >> I would also start the developers tools in Google Chrome or Firefox and
> >> have a look at the network requests the browser is making. You can then
> >> test the requests manually and compare with the Apache server log.
> >> It may also be that it is making request to GetProjectSettings and you
> >> have an older version of the server - in which case you can set
> >> var useGetProjectSettings = false;
> >> in GlobalOptions.js
> >> Andreas
> >> Am 09.12.2012 14:59, schrieb Otto Dassau:
> >>> Hi,
> >>> I installed qgis server version 1.8 using ubuntu precise. The WMS and
> >>> WFS work, if I add them to QGIS. Now I would like to play with the
> >>> qgis-web-client. I can see the web-client but the test maps "Hello" and
> >>> "Country" are loading and loading ... but are not visible.
> >>> I guess I missed something simple to configure. But the log files don't
> >>> say anything, except for some missing css files in blueprint.
> >>> Thanks for any hint
> >>> Otto
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
