[Qgis-user] Can not add postgis table
Andreas Neumann
a.neumann at carto.net
Tue Feb 7 00:00:51 PST 2012
Hi Nome,
Is pgAdmin3 on the client machine able to connect to Postgis on the
Server? QGIS is using libpq, as is pgAdmin3. So please check first that
pgAdmin3 from the client can connect to the server.
Were there any updates on PostgreSQL or QGIS recently?
Andreas
On Tue, 7 Feb 2012 19:09:54 +1400, Nomeneta Saili wrote:
> Hi list,
> I am having problems with adding my postGIS tables remotely through
> QGIS 1.7.
> It has worked before flawlessly until this morning. Now when i try to
> connect and add postgis table it its say "could not connect to server
> : connection timeout".
> My network is working fine and there were no changes made. My
> postgres
> server is up an running. I am able to connect and add my postgis
> tables through QGIS on my server that is running my Postgres server
> fine. Its when i try to access it from a client PC that is not
> working.
> The ports are opened the ph_hba config file is configured to allow
> access. Basically the same setting as before which was working until
> this morning.
> Does anyone has any idea where the problem might be?. I am able to
> access my mapserver and other services on my GIS Server but only this
> functionality is not work.
> Any help is appreciated.
> Thanks
> Nome
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
