[Qgis-user] Updating a table
Brett Adams
badams at spinifexgeophysics.com.au
Tue Feb 14 23:33:38 PST 2012
Alex,
You quite right, I was saving the points off to shape file first. I then
reimport the SHP file for editing.
It is here that the moved points don't seem to stick.
Sorry for the confusion
Brett
On 15/02/2012 3:24 PM, Alex Mandel wrote:
> On 02/14/2012 11:00 PM, Brett Adams wrote:
>> Hi Folks,
>> I've a bunch of points loaded in from a CSV file.
>> I then deleted a few, and moved some others. Saved the edit.
>> When I export the points the deleted points have gone but the moved
>> points remain the original position, not the new position.
>> How do I update the table to retain the new coords?
>> Thanks in advance
> Generally after import from csv you'll want to save the data into a
> spatial format (e.g. gml, shp or kml), just right click on the layer
> name and Save As... Once you've done that you can expect that edits
> should stick.
> It sounds like you hit an unexpected behavior in csv handling and we'll
> need to look in the tickets to see if someone has reported this before
> or if it can be fixed other than the work-around I mentioned above.
> Thanks,
> Alex
> Qgis-user mailing list
Brett Adams
Spinifex Geophysics <http://www.spinifexgeophysics.com.au/>
0438 861 974
SKYPE:brettadams_spinifex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120215/7e1630f6/attachment.html>
