[Qgis-user] Importing csv with UTM coordinates and zoning
Frederick Löbig
frederick.loebig at live.de
Wed Jan 11 05:28:07 PST 2012
Thanks Rainer, that was what I was thinking in the first place. Would have been nice if there'd be a simpler way. Thanks again,
Cheers,
Freddy
B.Eng. Frederick Löbig
Röderichstraße 59
60489 Frankfurt am Main
E:: Frederick.Loebig at grunsnid.de
P: +49 (0) 69 - 78 99 52 41
M: +49 (0) 174 - 70 89 296
Office:
euNetworks GmbH
Ludwig-Landmann-Straße 40560486 Frankfurt am MainP: +49 (0) 69 - 90 554 - 534
E: Frederick.Loebig at eunetworks.com
S: floebig
This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
> Date: Wed, 11 Jan 2012 14:26:11 +0100
> From: r.m.krug at gmail.com
> To: frederick.loebig at grunsnid.de
> CC: frederick.loebig at live.de; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Importing csv with UTM coordinates and zoning
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 11/01/12 14:13, Frederick Löbig wrote:
> > Hi all,
> > I have to import a csv containing a lot of coordinates which look
> > like this:
> > 51 20.930 N 01 26.290 E
> > sure thing, these are UTM coordinates. However, when I use the
> > "import text file as layer" tool, I have to define the right srs
> > first. For example, when I have a list of DHDN GK3 coordinates, I
> > set this up as the project's srs and define the layers srs to match
> > the source system from the coordinates in the csv. But, As you can
> > see, these coordiantes have the band-number in front of the
> > coordinate, so I don't know what I should the projects srs to. Is
> > it even possible to import a csv which containes coordinates in
> > this format?
> Don't know (and don't think so) - but you could always split the csv
> file, so that each resulting csv file is only one band, and then
> import them separately.
> Depending on what you want to do, you can then re-project them into a
> common coordinate system.
> Rainer
> > Thanks in advance. Freddy
> > **B.Eng. Frederick Löbig* Röderichstraße 59 60489 Frankfurt am
> > Main --- E:: Frederick.Loebig at grunsnid.de
> > <mailto:Frederick.Loebig at grunsnid.de> P: +49 (0) 69 - 78 99 52 41
> > M: +49 (0) 174 - 70 89 296 --- *Office:* *euNetworks GmbH*
> > Ludwig-Landmann-Straße 405 60486 Frankfurt am Main P: +49 (0) 69 -
> > 90 554 - 534 E: Frederick.Loebig at eunetworks.com
> > <mailto:Frederick.Loebig at eunetworks.com> S: floebig
> > the sender. *
> > _______________________________________________ Qgis-user mailing
> > list Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel : +33 - (0)9 53 10 27 44
> Cell: +33 - (0)6 85 62 59 98
> Fax : +33 - (0)9 58 10 27 44
> Fax (D): +49 - (0)3 21 21 25 22 44
> email: Rainer at krugs.de
> Skype: RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk8NjfMACgkQoYgNqgF2egptTgCfRV3hK60BQS2cxLPoNnGnsPrw
> txUAnjxlGC/GwfR85V+nvWXnviy91781
> =0fLB
> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120111/40c42913/attachment.html>
