[Qgis-user] Importing csv with UTM coordinates and zoning
Rainer M Krug
r.m.krug at gmail.com
Wed Jan 11 05:33:57 PST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 11/01/12 14:28, Frederick Löbig wrote:
> Thanks Rainer, that was what I was thinking in the first place.
> Would have been nice if there'd be a simpler way.
I would obviously not do this in QGIS, but any scriptable language - R
comes to mind, or GRASS (from bash if you are using Linux)
Cheers,
Rainer
> Thanks again,
> Cheers, Freddy
> **B.Eng. Frederick Löbig* Röderichstraße 59 60489 Frankfurt am
> Main --- E:: Frederick.Loebig at grunsnid.de
> <mailto:Frederick.Loebig at grunsnid.de> P: +49 (0) 69 - 78 99 52 41
> M: +49 (0) 174 - 70 89 296 --- *Office:* *euNetworks GmbH*
> Ludwig-Landmann-Straße 405 60486 Frankfurt am Main P: +49 (0) 69 -
> 90 554 - 534 E: Frederick.Loebig at eunetworks.com
> <mailto:Frederick.Loebig at eunetworks.com> S: floebig
> This email and any attachments may contain confidential and/or
> legally privileged information. If you are not the intended
> recipient, please delete the email without reading it and notify
> the sender. *
>> Date: Wed, 11 Jan 2012 14:26:11 +0100 From: r.m.krug at gmail.com
>> To: frederick.loebig at grunsnid.de CC: frederick.loebig at live.de;
>> qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] Importing csv
> On 11/01/12 14:13, Frederick Löbig wrote:
>> Hi all,
>> I have to import a csv containing a lot of coordinates which
>> look like this:
>> 51 20.930 N 01 26.290 E
>> sure thing, these are UTM coordinates. However, when I use the
>> "import text file as layer" tool, I have to define the right srs
>> first. For example, when I have a list of DHDN GK3 coordinates,
>> I set this up as the project's srs and define the layers srs to
>> match the source system from the coordinates in the csv. But, As
>> you can see, these coordiantes have the band-number in front of
>> the coordinate, so I don't know what I should the projects srs
>> to. Is it even possible to import a csv which containes
>> coordinates in this format?
> Don't know (and don't think so) - but you could always split the
> csv file, so that each resulting csv file is only one band, and
> then import them separately.
> Depending on what you want to do, you can then re-project them into
> a common coordinate system.
> Rainer
>> Thanks in advance. Freddy
>> 41 M: +49 (0) 174 - 70 89 296 --- *Office:* *euNetworks GmbH*
>> - 90 554 - 534 E: Frederick.Loebig at eunetworks.com
>> the sender. *
>> _______________________________________________ Qgis-user
>> mailing list Qgis-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk8Nj8UACgkQoYgNqgF2egpXHACfc1O3MQexpb2QCzO34eKEcw6O
uaYAmgKR5FEr9csXAH+lm0HT0TkvcWxW
=oPu+
-----END PGP SIGNATURE-----
