[Qgis-user] Publishing my map
Paul Lens
paul.lens at base.be
Mon Jan 30 09:44:01 PST 2012
In addition to Bob Basques's point 1.), there is an interesting tool in
Adobe Reader: the Loupe tool, which magnifies a portion of the page so
you can easily view details.
Paul
On 30/01/2012 18:17, Bob Basques wrote:
> Here would be my suggestions based on your needs.
> 1.) Make a PDF of the map. (the tools for making layer controls in PDFs exist, but are not easy to implement manually)
> 2.) Use something like OpenLayers or GeoMoose to display the map layers separately for user control (allows for the most flexibility for both publishing as well as user interaction)
> bobb
>>>> Gerhardus Geldenhuis<gerhardus.geldenhuis at gmail.com> wrote:
> Hi
> As part of my Geology thesis I need to present a map for which I have used QGIS to produce the map. However the printed map contains a lot less information because of space constraints. There is two options as far as I can see for making the digital map available to my lecturers for marking. One is via the viewer and the second via a custom web page. I were unable to see a working demo of the web based map. The only functionality I require is for people to be able to view the map turn on and off layers and zoom in/out. Based on this requirements does anyone have any alternative suggestions maybe a very large svg copy?, or any tips/tricks? Also a working link to a online map would be appreciated if anyone could share that.
> Best Regards
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120130/ed711c2a/attachment.html>
