[Qgis-user] Publishing my map
Andreas Neumann
a.neumann at carto.net
Mon Jan 30 11:12:35 PST 2012
I would suggest to use QGIS Server and QGIS webclient for this purpose.
Makes sense if you already have a configured QGIS project.
It would allow you to navigate, print parts of the map and display
attribute data. Users can also toggle map layers.
See http://gis.uster.ch/ for examples.
Andreas
On 01/30/2012 06:11 PM, Gerhardus Geldenhuis wrote:
> Hi
> As part of my Geology thesis I need to present a map for which I have used
> QGIS to produce the map. However the printed map contains a lot less
> information because of space constraints. There is two options as far as I
> can see for making the digital map available to my lecturers for marking.
> One is via the viewer and the second via a custom web page. I were unable
> to see a working demo of the web based map. The only functionality I
> require is for people to be able to view the map turn on and off layers and
> zoom in/out. Based on this requirements does anyone have any alternative
> suggestions maybe a very large svg copy?, or any tips/tricks? Also a
> working link to a online map would be appreciated if anyone could share
> that.
> Best Regards
> Qgis-user mailing list
