[Qgis-user] Re: Rasterlite layer is just a black box
ASAHI Kosuke
asahi at hcc.co.jp
Thu Mar 8 17:09:58 PST 2012
Hi Jukka.
My QGIS in WinXP work fine with rasterlite., but i need update sqlite3.dll.
Please try download latest dll, and copy to OSGeo4w\bin.
http://www.sqlite.org/download.html
(2012/03/09 4:49), Jukka Rahkonen wrote:
> Paolo Cavallini<cavallini at ...> writes:
>> Il 08/03/2012 19:45, Giovanni Manghi ha scritto:
>>> On Thu, 2012-03-08 at 18:27 +0000, Jukka Rahkonen wrote:
>>>> Hi,
>>>> Somebody had similar issue in January. QGis 1.9.0 opens rasterlite database
> fine
>>>> but the image does not show.
>>> Hi,
>>> here it shows just fine. I'm using qgis-master on Ubuntu 11.10 64 bit.
>> Just tested loading it from the browser, it works well.
>> Perhaps you can share a sample so we can test?
>> All the best.
> You mean my test database? As I wrote, it is here
> http://latuviitta.org/documents/herttoniemi.sqlite
> I am on Windows Vista (32-bit), and QGis is from OSGeo4W. And the info tool
> reports pixel values (0,0,0) all over the image area. QGis version is
> QGIS version
> 1.9.90-Alpha
> QGIS code revision
> f61988e
> Compiled against Qt
> 4.7.1
> Running against Qt
> 4.7.1
> GDAL/OGR Version
> 1.8.1
> GEOS Version
> 3.2.2
> PostgreSQL Client Version
> 8.3.10
> SpatiaLite Version
> 2.4.0
> QWT Version
> 5.2.1
> This copy of QGIS writes debugging output.
> -Jukka Rahkonen-
> Qgis-user mailing list
ASAHI Kosuke
