[Qgis-user] Re: Rasterlite layer is just a black box
Ramon AndiƱach
custard at westnet.com.au
Thu Mar 8 23:36:08 PST 2012
Jukka's file is not working in 1.7.4 or 1.9.90 (osgeo) on my win7 box, even with the updated dll.
I've loaded it through the DB manager. Using Layer->Add Spatialite Layer not working for me as it doesn't think there's any spatial layers (This could be driver error, I don't usually use SQL sources), but dragging the raster layer in I can see that there *is* information in the layer, but not in the raster field.
-ramon.
P.S. What's a BLOB.
On 09/03/2012, at 9:09, ASAHI Kosuke <asahi at hcc.co.jp> wrote:
> Hi Jukka.
> My QGIS in WinXP work fine with rasterlite., but i need update sqlite3.dll.
> Please try download latest dll, and copy to OSGeo4w\bin.
> http://www.sqlite.org/download.html
> (2012/03/09 4:49), Jukka Rahkonen wrote:
>> Paolo Cavallini<cavallini at ...> writes:
>>> Il 08/03/2012 19:45, Giovanni Manghi ha scritto:
>>>> On Thu, 2012-03-08 at 18:27 +0000, Jukka Rahkonen wrote:
>>>>> Hi,
>>>>> Somebody had similar issue in January. QGis 1.9.0 opens rasterlite database
>> fine
>>>>> but the image does not show.
>>>> Hi,
>>>> here it shows just fine. I'm using qgis-master on Ubuntu 11.10 64 bit.
>>> Just tested loading it from the browser, it works well.
>>> Perhaps you can share a sample so we can test?
>>> All the best.
>> You mean my test database? As I wrote, it is here
>> http://latuviitta.org/documents/herttoniemi.sqlite
>> I am on Windows Vista (32-bit), and QGis is from OSGeo4W. And the info tool
>> reports pixel values (0,0,0) all over the image area. QGis version is
>> QGIS version
>> 1.9.90-Alpha
>> QGIS code revision
>> f61988e
>> Compiled against Qt
>> 4.7.1
>> Running against Qt
>> 4.7.1
>> GDAL/OGR Version
>> 1.8.1
>> GEOS Version
>> 3.2.2
>> PostgreSQL Client Version
>> 8.3.10
>> SpatiaLite Version
>> 2.4.0
>> QWT Version
>> 5.2.1
>> This copy of QGIS writes debugging output.
>> -Jukka Rahkonen-
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> ASAHI Kosuke
