[Qgis-user] Re: Rasterlite layer is just a black box
    ASAHI Kosuke
    asahi at hcc.co.jp
    Thu Mar  8 23:48:54 PST 2012
Hi ramon.
How about use Layer→Add Raster Layer on qgis main menu?
(2012/03/09 16:36), Ramon Andiñach wrote:
> Jukka's file is not working in 1.7.4 or 1.9.90 (osgeo) on my win7 box, even with the updated dll.
> I've loaded it through the DB manager. Using Layer->Add Spatialite Layer not working for me as it doesn't think there's any spatial layers (This could be driver error, I don't usually use SQL sources), but dragging the raster layer in I can see that there *is* information in the layer, but not in the raster field.
> -ramon.
> P.S. What's a BLOB.
> On 09/03/2012, at 9:09, ASAHI Kosuke<asahi at hcc.co.jp>  wrote:
>> Hi Jukka.
>> My QGIS in WinXP work fine with rasterlite., but i need update sqlite3.dll.
>> Please try download latest dll, and copy to OSGeo4w\bin.
>> http://www.sqlite.org/download.html
>> (2012/03/09 4:49), Jukka Rahkonen wrote:
>>> Paolo Cavallini<cavallini at ...>   writes:
>>>> Il 08/03/2012 19:45, Giovanni Manghi ha scritto:
>>>>> On Thu, 2012-03-08 at 18:27 +0000, Jukka Rahkonen wrote:
>>>>>> Hi,
>>>>>> Somebody had similar issue in January. QGis 1.9.0 opens rasterlite database
>>> fine
>>>>>> but the image does not show.
>>>>> Hi,
>>>>> here it shows just fine. I'm using qgis-master on Ubuntu 11.10 64 bit.
>>>> Just tested loading it from the browser, it works well.
>>>> Perhaps you can share a sample so we can test?
>>>> All the best.
>>> You mean my test database? As I wrote, it is here
>>> http://latuviitta.org/documents/herttoniemi.sqlite
>>> I am on Windows Vista (32-bit), and QGis is from OSGeo4W. And the info tool
>>> reports pixel values (0,0,0) all over the image area. QGis version is
>>> QGIS version
>>> 1.9.90-Alpha
>>> QGIS code revision
>>> f61988e
>>> Compiled against Qt
>>> 4.7.1
>>> Running against Qt
>>> 4.7.1
>>> GDAL/OGR Version
>>> 1.8.1
>>> GEOS Version
>>> 3.2.2
>>> PostgreSQL Client Version
>>> 8.3.10
>>> SpatiaLite Version
>>> 2.4.0
>>> QWT Version
>>> 5.2.1
>>> This copy of QGIS writes debugging output.
>>> -Jukka Rahkonen-
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> ASAHI Kosuke
ASAHI Kosuke
