[Qgis-user] Re: Annoying CRS-Problem with EPSG 31468 / 2167: Conclusions?
bernhard.stroebl at jena.de bernhard.stroebl at jena.de
Thu Mar 22 08:35:18 PDT 2012
Am 22.03.2012 16:05, schrieb Bernd Vogelgesang:
> So, the problem was now described thoroughly, but what are the
> conclusions now?
There is already a ticket open http://hub.qgis.org/issues/4977
although I have no idea if the issue has been solved or not
> I'm going to spread QGIS in my region in the next months, and it's quite
> hard to explain to the people, who to 99% work with EPSG 31468-data,
> that they can't ever rely on any data they produce and that they have to
> double-check each layer after creation for the right CRS, even if they
> set it correctly in each setting available?!?
> I'm not too familiar with all those packages involved handling the CRSs,
> so can someone please point me the way who to address with this problem?
> For novice QGIS-users, this "bug" is a real exclusion criterion for QGIS
> for they will only create crap with it!
> Again my findings:
> Options settings: new layers and projects are created with EPSG 31468,
> promting for CRS ist set.
> - EPSG 31468-Layers with a prj-file from ArcGIS get loaded as 2167
> without promting for the CRS
> - EPSG 31468-Layers loaded into a EPSG 31468-Region in GRASS are handed
> back to QGIS as ... 2167
> - New Layers created in some plugins (like some ftools-plugins), added
> to the TOC, are in ... 2167 .. or even 3397
> What can i do? (And i really wonder what all those other german users do
> and why the don't complain...)
For me the base of the problem seems to be that the prj file is not
matched to the right EPSG srs. As soon as you tell the layer it is
EPSG:31468 it is positioned correctly. So the problem arises only with
shapefiles; at my work we use PostGIS for most of our data (that is of
course no help for you but explains why I am not "complaining")
Bernhard
> Thanx for advice
> Bernd
> (QGIS 1.7.4, osgeo4w advanced install, Win7 64bit)
> Qgis-user mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
