[Qgis-user] Re: Annoying CRS-Problem with EPSG 31468 / 2167: Conclusions?
Torsten Lange tlange at gwdg.de
Thu Mar 22 10:11:04 PDT 2012
Am Donnerstag 22 März 2012, 16:35:18 schrieb bernhard.stroebl at jena.de:
> Am 22.03.2012 16:05, schrieb Bernd Vogelgesang:
> > So, the problem was now described thoroughly, but what are the
> > conclusions now?
> There is already a ticket open http://hub.qgis.org/issues/4977
> although I have no idea if the issue has been solved or not
I haven't been aware of this as well. However, as stated in the comments for the ticket, in Debian there is this 'crssync' tool. For my case at least it assigns the depricated id 31463 instead of the currently valid id 31467 (which I just checked). Except for the id there is no shifting..., that's why _I_ didn't complain. Anyway it waked me up to be more "checky" ;)
> > I'm going to spread QGIS in my region in the next months, and it's quite
> > hard to explain to the people, who to 99% work with EPSG 31468-data,
> > that they can't ever rely on any data they produce and that they have to
> > double-check each layer after creation for the right CRS, even if they
> > set it correctly in each setting available?!?
> > I'm not too familiar with all those packages involved handling the CRSs,
> > so can someone please point me the way who to address with this problem?
> > For novice QGIS-users, this "bug" is a real exclusion criterion for QGIS
> > for they will only create crap with it!
> > Again my findings:
> > Options settings: new layers and projects are created with EPSG 31468,
> > promting for CRS ist set.
> > - EPSG 31468-Layers with a prj-file from ArcGIS get loaded as 2167
> > without promting for the CRS
> > - EPSG 31468-Layers loaded into a EPSG 31468-Region in GRASS are handed
> > back to QGIS as ... 2167
> > - New Layers created in some plugins (like some ftools-plugins), added
> > to the TOC, are in ... 2167 .. or even 3397
> > What can i do? (And i really wonder what all those other german users do
> > and why the don't complain...)
> For me the base of the problem seems to be that the prj file is not
> matched to the right EPSG srs. As soon as you tell the layer it is
> EPSG:31468 it is positioned correctly. So the problem arises only with
> shapefiles; at my work we use PostGIS for most of our data (that is of
> course no help for you but explains why I am not "complaining")
> Bernhard
> > Thanx for advice
> > Bernd
Torsten
