[Qgis-user] Database design/performance question
Etienne Tourigny
etourigny.dev at gmail.com
Wed May 9 17:39:09 PDT 2012
How about spatialite? Does it suffer from performance issues when a
file gets large (say ~1GB)?
Etienne
On Wed, May 9, 2012 at 9:36 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Performance wise it does not matter whether you have one or multiple
> databases. You can also split a single database into multiple tablespaces on
> multiple disks.
> I would opt for one big database for everything. Table joins across multiple
> databases is complicated and does not work out of the box in PostgreSQL. The
> only drawback with one big database is that the dump files (backup or
> migration) get fairly large.
> Andreas
> On Wed, 9 May 2012 13:48:38 +0700, Koos Hagg wrote:
>> Hi all,
>> Only recently have I started using databases more often. I like
>> Spatialite for its single file solution, I can easily share data with
>> others... PostGIS is great too, happy that they have 64 Windows now.
>> Performance wise- in QGIS:
>> Is it better to have one big Database (PostGIS or Spatialite or
>> whatever) with all of your layers/tables in there, or to have several
>> smaller databases, each containing their own family of data
>> For example,
>> I could have one database for OSM data from Geofabrik, one database
>> with Natural Earth data, and one database with my own data., etc
>> -or-
>> I could stuff all of those into one big database.
>> Which approach is the better practice? Will accessing several
>> databases in QGIS at the same time vs one big db be any different in
>> performance?
>> If I'm working with PostGIS, would it make sense to separate the
>> different data groups (OSM, Natural Earth, etc) into different
>> schemas? Would there be any benefit to that?
>> Thanks!
>> Koos
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-user mailing list
