[Qgis-user] rendering problem in print composer
Jake Maier
j.m at jmforestry.com
Tue May 15 03:13:35 PDT 2012
Thank you Andreas for your suggestion. I'll try the svg file later.
The misalignment happens in the actual paper print out, on screen, and also when I export it to a jpg file. Again each time the legend is correct but on the actual map is misaligned and it looks like it's just the 90 degree turning of the individual parts that is not happening. The enlarging and lowering or raising of the parts is happening.
Thank you again for your time
Jake
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: Tuesday, May 15, 2012 2:25 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] rendering problem in print composer
Hi Jake,
This sounds very strange. Is this only happening in the print composer preview or also in the actual print out (PDF or real print out).
Older QGIS versions (1.7 and below) did not show the print previews in the print composer with the correct scalings (the map extent was correct, but symbol sizes, line-widths and text sizes were not (usually drawn bigger compared to the print out)).
In your case I would recommend that you create an SVG file with your birdhouse (you can do that in Inkscape or Adobe Illustrator). You then can use this bird house SVG file to represent your bird house symbol.
Hope this helps,
Andreas
On Mon, 14 May 2012 17:11:59 -0400, Jake Maier wrote:
> I created a custom point, (stylist bird house) and it looks like a
> birdhouse in QGIS but when I bring the map into print composer the
> lines are misplaced. Creating the bird house, I lowered respective
> raised a straight line and turned it 90 degrees for floor and ceiling
> and used a > 90 degrees turned as roof. Again it all looks ok when
> displayed in qgis but when I bring it into the print composer all part
> seem to print on the same level and not turned 90 degrees. Strangely
> the legend prints the houses correctly.
> Did I find my second bug or do I just miss an important step?
> Can anyone please help?
> Jake
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
