[Qgis-user] labels
Jake Maier
j.m at jmforestry.com
Wed May 23 05:26:34 PDT 2012
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at faunalia.pt]
> Sent: Wednesday, May 23, 2012 7:55 AM
> To: Jake Maier
> Cc: qgis-user at lists.osgeo.org
> Subject: RE: [Qgis-user] labels
> Hi,
> > I now managed to turn the move and rotate label on, but only to have
> > all labels disappear when I assign the fields in data defined
> settings
> > (I guess because of the initial value of 0).
> yes, it should be because you have the columns filled with zeroes.
> Change the to NULL and it should work as expected.
> > > How can I fill the coordinate fields with the initial values
> without
> > > having to enter all the values manually?
> change the column values to empty values or nulls and it should work.
> Nevertheless you will probably notice an issue with rotation: having a
> column with rotation values/angles does not rotate automatically all
> the labels (you need to click on each label with the "rotate label"
> tool to have the value appplied).
> cheers
> -- Giovanni --
[JM]
Thanks Giovanni, this is a hard nut to crack for me for whatever reason.
I insert a new field with table manager and it will enter the zeros in each cell automatically. I have many soils to deal with and don't want to enter a null in each cell manually. How can I fill the column with nulls or delete all of them painlessly? :)
Jake
