[Qgis-user] Label missing in Weekly
Nathan Woodrow
madmanwoo at gmail.com
Thu Aug 1 15:02:32 PDT 2013
Hey,
QgsExpression doesn't treat NULL and Empty string as the same thing. Which
is why we don't auto convert. To convert nulls in a field you should use
the coalesce("Areatype",'')
See http://hub.qgis.org/issues/8369
- Nathan
On Fri, Aug 2, 2013 at 7:35 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Lene,
> On Thu, Aug 1, 2013 at 2:25 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>> Hi Goyo
>> The geometries is OK.
>> I have a combined label Ex.
>> Areatype || '\n' || $Area || ' m2'
>> Now I found that if one field is empty (Even if there is NULL in the
>> field), then the entire label will not be displayed.
> When the expression-based label text was introduced, NULL values
> supposedly where just converted to empty strings [0], i.e. if Areatype was
> NULL, one would expect at least 'm2' to be present in the label.
> Try enclosing your field name Areatype in double quotes. Also, try without
> the $Area function, but still with the || concatenation. If the label still
> does not contain any text, then it is probably a bug in how QgsExpression
> handles NULL values from the data provider. If so, please create an issue
> ticket [1]. Include a test project file, and try to list reproducible
> steps, if you can.
> [0]
> http://osgeo-org.1560.x6.nabble.com/Expression-based-labeling-tp4100735p4100736.html
> [1] http://hub.qgis.org/projects/quantum-gis/issues
> Regards,
> Larry
>> Regards
>> Lene
>> ________________________________________
>> Fra: Goyo [goyodiaz at gmail.com]
>> Sendt: 1. august 2013 20:40
>> Til: Lene Fischer
>> Cc: qgis-user at lists.osgeo.org
>> Emne: Re: [Qgis-user] Label missing in Weekly
>> 2013/8/1 Lene Fischer <lfi at life.ku.dk>:
>> > Hello
>> > I´m using the new labelfunction - it is great!! - but som of the labels
>> are
>> > missing. I have a small project with only 9 polygons, but only 7 labels
>> is
>> > visible.
>> > I´ve tried:
>> > Settings to "View all labels in all layers"
>> > change attributefield and size
>> > Same result. Any suggestions?
>> > Regards
>> > Lene Fischer
>> You might have invalid geometries. They are not labelled IIRC.
>> Goyo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130802/be38d943/attachment.html>
