[Qgis-user] MrSID raster and QGIS in linux
Eric Goddard egoddard1010 at gmail.com
Tue Dec 3 08:05:40 PST 2013
Hmm, I don't think you could've made it past the compiling gdal steps
if the geotiff package wasn't installed. In the cmake window for
configuring libLAS, do you have Values for GEOTIFF_INCLUDE_DIR and
GEOTIFF_LIBRARY? I have /usr/include/geotiff and /usr/lib/geotiff.so,
respectively.
Keep in mind that if you only want to compile QGIS you don't have to
compile LASzip, libLAS, or GRASS 7.
Eric
On Tue, Dec 3, 2013 at 9:49 AM, BigBaka <hunt.glenn at gmail.com> wrote:
> Hi Eric,
> Thanks for this link to install MrSID/ECW support on ubuntu. I'm using 12.04
> 64 bit. Have been trying to follow your instructions but ran into trouble
> when trying to configure and compile ilbLAS at this point
> #Same as LASZip, click configure, select unix makefiles.
> #This time there will be more options. Check the boxes beside WITH_GDAL,
> WITH_GEOTIFF, #and WITH_LASZIP and click configure again. If no errors are
> reported you can click #“Generate” #and close cmake-gui.
> After checking the 3 boxes as directed when I click configure the second
> time I get the following readout with errors reported on GEOTIFF.
> "Setting libLAS build type - Release
> Searching for Boost 1.38+ - done
> Searching for LASzip 2.0.1+ library
> Found LASzip version: 2.2.0
> Searching for GDAL 1.7.0+ library
> Searching for GeoTIFF 1.2.5+ library
> Could NOT find GeoTIFF (missing:  GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
> (Required is at least version "1.2.5")
> CMake Error at CMakeLists.txt:270 (message):
>   GDAL support requires GeoTIFF library which was not selected
> Configuring incomplete, errors occurred!"
> Do you have any advice as to what I could do to fix this?
> Regards,
> BigBaka
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092429.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
