[Qgis-user] Field calculator issue
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Dec 3 09:10:33 PST 2013
Hi Carlos,
There was this issue which has been fixed in Master apparently:
http://hub.qgis.org/issues/8895
Jonathan
On 26 November 2013 13:13, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi list:
> (Maybe related with Rob Vech e-mail: strange results when calculating area
> and perimeter )
> I'm was trying calculate area of a layer with two polygons, but I can't
> get right values. Layer and project are in UTM 17s (epsg 32717) projection.
> I want square kilometers, so the used expression is:
> $area/100000
> Field type is real, 10 digits, 2 decimals (also tryed with 15 digits) buth
> result is wrong for one polygon and zero for second.
> The layer has not geometric errors (I've check it), and can be download
> from
> https://sites.google.com/site/ccerdan/Home/Cuencas_Cajamarca.zip?attredirects=0&d=1
> There are a field "Area_KM2" that was calculated in ArcGIS and it has the
> right values. The "Area_Ha" has the (wrong) result of QGIS field calculator.
> What is wrong with field calculator?
> UPDATE: After a reboot, field calculator found the right values... but
> What was wrong?
> Carlos
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131203/405c5650/attachment.html>
