[Qgis-user] QGIS Server on CentOS 6
    Andreas Neumann
    a.neumann at carto.net
    Sun Feb  3 03:10:14 PST 2013
Can you tell us what documentation you worked with? At what steps do you
have problems? What is working what is not? The problem of the
documentation is that every OS puts Apache files in other paths. The
other thing is that you can put your file everwhere you want as long as
you configure Apache correctly. So it is impossible to document the
process for all systems. But we can certainly improve the documentation.
Is QGIS server working at all? Did you test running QGIS server and use
QGIS desktop as a client?
It is usually a several step process to set up:
1. install of the fcgi binaries (or compile from source)
2. Install Apache
3. configure apache for using mod_fcgi
4. test QGIS server manually (GetCapbilities, GetMap, GetFeatureInfo)
5. test QGIS server with QGIS Destkop as a client
6. install the necessary files of QGIS web client
7. Copy GlobalOptions.js file from one of the templates
8. Edit GlobalOptions.js - e.g. set the path to your fcgi, decide
whether to use GetCapabilities (older QGIS server, e.g. QGIS 1.8) or
GetProjectSettings (newer QGIS server, current master)
If anything fails you can fire up the developer tools in Google Chrome
or Firebug - have a look at the network requests where the client calls
the fcgi file. Copy that URL and see if it works or why not (e.g. wrong
paths).
Hope this helps a bit,
Andreas
Am 03.02.2013 02:17, schrieb bogusman:
> I'm a GIS newbie though an old hand in other technologies. Just today brought
> up QGIS Server on CentOS 6 - at least that worked - I tried for 2 days to
> get it working on Debian and failed miserably.
> I'm not yet found an adequate tutorial that tells me just how to get a QGIS
> project working from apache. The tutorials I've found are only marginally
> helpful in s/w installation, but none at all that give guidance as to
> how/where to put server related files, not to mention documenting a
> querystring to get a simple map back.
> Am I missing something somewhere? Can anyone point me to a decent starting
> point? I don't mind reading but so far have not found much helpful to read.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-Server-on-CentOS-6-tp5031714.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
