[Qgis-user] Executing qgis after building from git results in errors and warnings
Timo Grossenbacher wnstnsmth at yahoo.com
Mon Feb 11 07:22:31 PST 2013
I built the latest QGIS version on Ubuntu 12.04, following exactly these
steps:
http://www.qgis.org/api/INSTALL.html#toc3
The only things I changed in ccmake .. were setting
CMAKE_INSTALL_PREFIX=/home/tgrossen/Apps/QGIS and WITH_PYSPATIALITE=ON
Before make install, I conducted tests with make test:
93% tests passed, 4 tests failed out of 57
Total Test time (real) = 297.32 sec
The following tests FAILED:
	  9 - qgis_rasterlayertest (Failed)
	 28 - qgis_composerhtmltest (Failed)
	 41 - PyQgsRasterLayer (Failed)
	 51 - PyQgsComposerMap (Failed)
Errors while running CTest
make: *** [test] Error 8
As you can see, make test itself crashed.
After make install, I also had to do this:
http://hub.qgis.org/wiki/quantum-gis/Building_QGIS_from_Source, which
fortunately worked.
Anyway,there are several things that are weird when executing the qgis
binary:
tgrossen at tgrossen-VirtualBox:~/Apps/QGIS/bin$ ./qgis
Warning: loading of qgis translation failed
[/home/tgrossen/Apps/QGIS/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]
And then, after the desktop has loaded, I want to open up a Python shell,
but that's what I get:
exceptions.ImportError: No module named Qsci
1. Question: What do I have to do in order to use the Python console?
2. Question: I explicitly compiled pyspatialite, now where do I find this
library and how can I include into my regular Python path, so I can use it
outside of QGIS too?
wnstnsmth.net
View this message in context: http://osgeo-org.1560.n6.nabble.com/Executing-qgis-after-building-from-git-results-in-errors-and-warnings-tp5033486.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
