[Qgis-user] QGIS Server 1.8 getPrint returns empty map
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Feb 13 23:46:12 PST 2013
Hi Anita
I cannot access the server url. However, I suppose the empty map is
because the x-/ and y-coordinates in WMS 1.3 are exchanged (for most
geographic coordinate systems). Does it work if you use
map0:extent=48.0,16.1,48.4,16.6 ?
Regards,
Marco
On 13.02.2013 11:50, Anita Graser wrote:
> Thanks Bernhard!
> On Wed, Feb 13, 2013 at 11:08 AM, Bernhard Ströbl
> <bernhard.stroebl at jena.de> wrote:
>> please check if it is related to this problem
>> http://hub.qgis.org/issues/5782
> According to the linked conversation
> "The original version was only done for meters, so we did not use more
>   than one digit after the comma for specifying the print extent."
> The extent I'm using would be none zero if at least one digit after
> the comma is considered. So that's probably not the source of the
> problem.
>> I also remember a decimal-separator problem with QGIS 1.8 (which applies if
>> you are using the German , in your system's settings and thus in the
>> composer). Marco Hugentobler fixed that but I am not sure if the fix has
>> been backported. So maybe you should update your server to current master.
> Thanks, I'll check that though I think the server runs English Ubuntu anyway.
> Best wishes,
> Anita
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
