[Qgis-user] QGIS Server 1.8 getPrint returns empty map
Anita Graser
anitagraser at gmx.at
Thu Feb 14 00:33:54 PST 2013
Thanks Marco,
Unfortunately it's only an internal server which cannot be accessed
from the outside.
No luck so far even with x/y exchanged. Is the BBOX parameter
necessary and in which order should coordinates be?
http://10.101.21.28/cgi-bin/qgis_mapserv.fcgi?MAP=/usr/lib/cgi-bin/vienna/vienna.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetPrint&TEMPLATE=Composer
1&Map0:extent=48.0,16.1,48.4,16.6&BBOX=48.0,16.1,48.4,16.6&CRS=EPSG:4326&FORMAT=pdf&DPI=300&TRANSPARENT=true
I also created a version using a metric CRS to test if that could
cause problems but same results.
Maybe we could have an example project (based on QGIS sample data) and
a working getPrint request for this project. I would be very thankful
if someone could provide such.
Best wishes,
Anita
On Thu, Feb 14, 2013 at 8:46 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Anita
> I cannot access the server url. However, I suppose the empty map is because
> the x-/ and y-coordinates in WMS 1.3 are exchanged (for most geographic
> coordinate systems). Does it work if you use map0:extent=48.0,16.1,48.4,16.6
> Regards,
> Marco
> On 13.02.2013 11:50, Anita Graser wrote:
>> Thanks Bernhard!
>> On Wed, Feb 13, 2013 at 11:08 AM, Bernhard Ströbl
>> <bernhard.stroebl at jena.de> wrote:
>>> please check if it is related to this problem
>>> http://hub.qgis.org/issues/5782
>> According to the linked conversation
>> "The original version was only done for meters, so we did not use more
>> than one digit after the comma for specifying the print extent."
>> The extent I'm using would be none zero if at least one digit after
>> the comma is considered. So that's probably not the source of the
>> problem.
>>> I also remember a decimal-separator problem with QGIS 1.8 (which applies
>>> if
>>> you are using the German , in your system's settings and thus in the
>>> composer). Marco Hugentobler fixed that but I am not sure if the fix has
>>> been backported. So maybe you should update your server to current
>>> master.
>> Thanks, I'll check that though I think the server runs English Ubuntu
>> anyway.
>> Best wishes,
>> Anita
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
