[Qgis-user] Minor Sextante modifications (grass and sqlite3.dll)
Victor Olaya volayaf at gmail.com
Tue Feb 19 07:50:44 PST 2013
I agree 100% with Paolo. If you can just check and tell us which
algorithms cause problems or have issues like the one you found, it
will greatly help us.
By the way, I will take care of adding the two versions of the
algorithm that you suggested.
Thanks again
Victor
2013/2/19 Paolo Cavallini <cavallini at faunalia.it>:
> Il 19/02/2013 16:21, magerlin ha scritto:
>> I am not a programmer and I think it was pure luck I was able to solve this
>> problem, so I am afraid I will not be able to do anything else than testing.
> any user can help substantially; more specifically, in this case:
> * having a comparison of modules (matching and non-matching) between the grass plugin
> and sextante would greatly help focusing efforts
> * of the non-matching, many will probably be useless (related to projection
> management for instance)
> * so having a short list of the truly missing ones would help a lot.
> Writing those missing, as you have already noticed, is not a programmer's job: just a
> text string with command and parameters.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> Qgis-user mailing list
