[Qgis-user] Fwd: New Plugin testing - Multipart Split
Alexandre Neto
senhor.neto at gmail.com
Mon Feb 25 02:26:31 PST 2013
Hello Vinayan,
Thanks for your feedback.
On Mon, Feb 25, 2013 at 8:04 AM, vinayan <vinayan123 at gmail.com> wrote:
> Hi Alexandre,
> I used it quite a few times this week and it looks good. This was a much
> needed tool for digitization(nobody like to export new layer for just
> splitting a couple of features..right?).
> It would be great if you can update it to the latest Qgis version(1.9). It
> would also be useful to keep the source in Github.
I have tested it in master and I got no errors, therefore I assumed it was
working. Did you have any problems with it?
I already put it in github: https://github.com/SrNetoChan/MultipartSplit
> Just a note i would like to add regarding usage..At present, there is no
> notification when the splitting is completed. What about clearing the
> current selection when splitting is complete?
You are right, something is needed to inform the user about the end of the
splitting process. Initially I though about deselecting the features, but I
realized that the user might want to continue working on that selection.
I'm studying how to use the bottom left information corner, and print
something like "10 Multipart feature(s) whore splited into 34 new one(s)".
What do you think?
> Once again, thanks for this nice tool.
> Thank you,
> Vinayan
> I will take advantage of your goodwill and ask your opinion about
something. I was thinking about adding a new functionality. If no feature
is selected in the current layer, the plugin would ask if the user wants to
split ALL multipart features. If the answer is yes, the code will cycle
through all features and try to split, if the answer is no, the procedure
is cancelled. What do you think?
Best regards,
Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130225/aed0ef6f/attachment.html>
