[Qgis-user] Internal Server Error when PDF printing from QGIS	Web Client
    cdp
    cdaponte at synergyaspen.ca
    Wed Jul  3 12:36:55 PDT 2013
Hi again everyone,
So finally managed to update the QGIS Server and QWC (2 days ago).  Just
noticed that the work around I found for getting pdf printing to work no
longer fixes the issue.  I've removed the work around to see if the standard
configuration would result in a pdf.
Here are 2 new getprint requests
--This is for a image/png which works just fine.
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=C:/projects/pt2.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=image/png&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:3005&DPI=150&TEMPLATE=Test%20Composer&map0:extent=1306326,1269471.5,1306464,1269565.5&map0:rotation=0&map0:scale=500&map0:grid_interval_x=50&map0:grid_interval_y=50&LAYERS=VIEWS_2%2Cafclty_bc&OPACITIES=255%2C255
--This one is for a pdf and results in a Internal Server Error.
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=C:/projects/pt2.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=pdf&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:3005&DPI=150&TEMPLATE=Test%20Composer&map0:extent=1306326,1269471.5,1306464,1269565.5&map0:rotation=0&map0:scale=500&map0:grid_interval_x=50&map0:grid_interval_y=50&LAYERS=VIEWS_2%2Cafclty_bc&OPACITIES=255%2C255
Any thoughts on what's causing the issue???
Thanks!
C
View this message in context: http://osgeo-org.1560.x6.nabble.com/Internal-Server-Error-when-PDF-printing-from-QGIS-Web-Client-tp5056774p5063897.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
