[Qgis-user] KML to SHP - max. 80 letters TXT fields
Werner Macho
werner.macho at gmail.com
Thu Jul 4 00:33:28 PDT 2013
Hi!
What you might probably read is
https://en.wikipedia.org/wiki/Shapefile
Shapefiles have a lot of limitations in it .. but as far as I know you
should be able to have 255 letters in a text field ..
Could you provide such a kml file somewhere to have a look at it?
regards
Werner
On Thu, Jul 4, 2013 at 8:50 AM, Compservice Agro Valigursky
<agro at compservice.sk> wrote:
> Hello,
> When I was looking for solution of my problem, I've found your website.
> I am regular user of QGIS. Using this for conversion from KML to SHP.
> But now i have faced one problem.
> If you would be so kind and find one minute, to help me with this problem,
> My steps, what I do:
> I add in QGIS vector layers, specifically KML file. Added KML contains
> labels in length cca 200 letters.
> After adding, is everything ok, I see whole length of labels.
> Then I save layer in format Shape.
> But in this step, my labels get uncut to length only 80 letters.
> Apparently it is necessary to modify the structure of the fields to more
> length.
> But It's problem to do it.
> Can you help me?
> PeVa
> Qgis-user mailing list
