[Qgis-user] Crash: merge shapefiles
Jonathan Webb jonathan at jwebbgis.co.uk
Fri Jul 5 08:45:30 PDT 2013
ArcGis refugee using QGIS 1.8.0-Lisboa on Windows 7 64 bit.
Trying to merge a quantity of (Ordnance Survey) height shapefiles & QGIS
crashes.
I've read around and there seems to be a bug
(http://hub.qgis.org/issues/5962) but the thread was marked as closed so
I'm not sure what the situation is.
It seems that it will work if there are .prj files, so as a workaround I
can create these.
As I've got loads of shapefiles, to define the .prj for each is not
realistic (Vector>DataManagement Tools>Define Current Projection).  I've
looked for a bulk process to create these but without luck
Do I need prj files & if so, how can I create a load of them?
Thanks.
Jonathan Webb
Freelance GIS Specialist
07941 921905
www.jwebbgis.co.uk
http://uk.linkedin.com/in/jwebbgis
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130705/a8f54f3b/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130705/a8f54f3b/attachment.vcf>
