[Qgis-user] Crash: merge shapefiles
Hugo
hfpmartins at gmail.com
Fri Jul 5 09:38:46 PDT 2013
Hi Jonathan,
You can use ogr2ogr to recursively create those PRJ files.
You will need to make a bash script or bat file (depending on your platform
of choice) that can read all your input shapefiles from a folder and
execute the following command for each one of those:
ogr2ogr -a_srs EPSG:27700 output.shp input.shp
Obviously I'm assuming that you are using British National Grid hence the
option -a_srs EPSG:27700. You can change this if you have your data in
other projection.
Hope this helps.
Cheers,
Hugo Martins
www.lutraconsulting.co.uk
On Fri, Jul 5, 2013 at 4:45 PM, Jonathan Webb <jonathan at jwebbgis.co.uk>wrote:
> Hi,
> ArcGis refugee using QGIS 1.8.0-Lisboa on Windows 7 64 bit.
> Trying to merge a quantity of (Ordnance Survey) height shapefiles & QGIS
> crashes.
> I've read around and there seems to be a bug (
> http://hub.qgis.org/issues/5962) but the thread was marked as closed so
> I'm not sure what the situation is.
> It seems that it will work if there are .prj files, so as a workaround I
> can create these.
> As I've got loads of shapefiles, to define the .prj for each is not
> realistic (Vector>DataManagement Tools>Define Current Projection). I've
> looked for a bulk process to create these but without luck
> Do I need prj files & if so, how can I create a load of them?
> Thanks.
> Jonathan Webb
> Freelance GIS Specialist
> 07941 921905
> www.jwebbgis.co.ukhttp://uk.linkedin.com/in/jwebbgis
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130705/2a7c8b0c/attachment.html>
