[Qgis-user] Crash: merge shapefiles
Giovanni Manghi giovanni.manghi at faunalia.pt
Fri Jul 5 14:25:36 PDT 2013
> As I've got loads of shapefiles, to define the .prj for each is not
> realistic (Vector>DataManagement Tools>Define Current Projection).  I've
> looked for a bulk process to create these but without luck
> Do I need prj files & if so, how can I create a load of them?
in QGIS master you can use SEXTANTE to batch process files, so you can
use the "reproject layer" tool, and get a copy of your shapes with a
proper .prj
Then to merge the shapes you can use QGIS, but I agree that is very
(very) slow for large shapes or large number of shapes.
The faster tool/code I tested is
http://gistncase.blogspot.pt/2012/05/python-shapefile-merger-utility.html
and it would be very nice to use it to replace the actual python code
of the merge shapefiles qgis tool, see
http://hub.qgis.org/issues/7208
cheers
-- Giovanni --
