[Qgis-user] QGIS with SAGA in macos
gvSIGMac gvsig.mac at gmail.com
Thu Jun 13 04:04:42 PDT 2013
William,
See below
On 13/06/2013, at 06:01, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I don't remember if there was an error running SAGA commands when I was checking things out.  I do remember that compiling SAGA 2.0.x was a problem on OS X and 2.1 dev source or RC is required.
I'm running 2.1
> I only tested the theissen polygons that Sextante uses as a test for the presence of SAGA
Vector commands run well to the extent I tried.
> What SAGA command are you running, and is it from Sextante (in QGIS), or in SAGA (not in QGIS)?
I was preprocessing a dem with sink filling, but other raster commands fail in the same manner.
> Where did you get your SAGA - did you compile from source, or was a binary from somewhere?  I compiled just the commands, without any GUI or python, neither used in sextante.
I did compile it but with both GUI and python.
Anyhow what worries me more is that I can write any raster because from sextante (maybe a bad python installation)
An error has occured while executing Python code:
  File "/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante/gui/OutputSelectionPanel.py", line 92, in saveToFile
    filename= unicode(files.first())
AttributeError: 'list' object has no attribute 'first'
Python version:
2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
QGIS version:
1.9.0-Master Master, 499db4e
Python path: ['/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante', '/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python', '/Users/adiez/.qgis2/python', '/Users/adiez/.qgis2/python/plugins', '/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/MapServer.framework/Versions/6.0/Python/2.7', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7', '/usr/local/lib/wxPython-2.9.4.0/lib/python2.7/site-packages', '/usr/local/lib/wxPython-2.9.4.0/lib/python2.7/site-packages/wx-2.9.4-osx_cocoa', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', '/usr/local/lib/wxPython-2.9.4.0/lib/python2.7', '/Applications/QGIS_2.0-dev.app/Contents/Resources/python/plugins/fTools/tools', '/Volumes/BoquiqueHD/Users/adiez/Dropbox/mursilandia']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130613/cef26b4a/attachment.html>
