[Qgis-user] Liz map web client
kimaidou
kimaidou at gmail.com
Wed Nov 13 12:12:07 PST 2013
By the way, after installing the Lizmap plugin, you should have a submenu
"Help" wich directly open the documentation translated by Google Translate
in your language.
2013/11/13 kimaidou <kimaidou at gmail.com>
> Hi all,
> At present there is no English version yet... But you can use the help or
> Google translation tool to get it in approximative English (readable though)
> http://translate.google.fr/translate?hl=fr&ie=UTF8&prev=_t&sl=fr&tl=en&u=http://docs.3liz.com/&sandbox=0&usg=ALkJrhj4LjA0_x5-cpecACMSDqRxidRIQQ
> Sorry for the inconvenience. We have (for a while...) the project to move
> our documentation inside QGIS, as proposed by Paolo. First step is to write
> down a good version in English, then use pootle / sphinx, etc. to let
> people help us translate in other languages.
> Michael
> 2013/11/13 Alex Mandel <tech_dev at wildintellect.com>
>> On 11/13/2013 10:41 AM, Paolo Cavallini wrote:
>> > Il 13/11/2013 19:39, Solly Vuso ha scritto:
>> >> Hi
>> >> I have installed liz map client on linux , can someone please outline
>> for me how to
>> >> add a qgis project on liz map client
>> > Have you red the documentation? It is pretty straightforward.
>> > All the best.
>> Which documentation are you referring to?
>> I just took a peak at
>> http://docs.3liz.com/en/lizmap-web-client/index.html
>> Which is supposed to be in English but apparently is the french version.
>> Then there's the lizmap plugin and the lizmap web client. It's not 100%
>> clear if you need both?
>> Guess my point is that it's not even clear where the documentation is,
>> so providing links would be helpful.
>> Thanks,
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131113/92068dde/attachment.html>
